fcross69
- Jul 5, 2012
- 36
I was out on the water yesturday after doing a prop swap installed how the Fleet Admiral guided me. As soon as i got going my motor started bucking banging on my transom. I pulled the cover to notice that the shifting rod was trying to move when motor was bucking. My cables are adjusted correctly I am wondering why my motor is trying to kick itself out of gear. I instantly trailored it and went right to the the drain plug on lower unit and out came the evil white milkyness. I have no metal flakes coming out at all even ran a magnet through the oil. I dropped the lower unit and hooked up a fitting so I could pressure test it for a water leak she holds a 100 PSI with no leak down while shifting lower unit into gear and spinning prop. Any ideas of what I should do next or would water in my oil make it try to kick out of gear under a load?? I even had the cover off with cable disconnected with my best friend shift gears for me by hand reverse gear worked with no issues but forward was still kicking it out even with him shifting by hand and I even lifted motor to make sure shifting rod was going all the way in and it was. So I am lost and pleading for help on this... I my serial number is 7039 my model number is 757ha I do believe its a 1974 but not sure I have no way to refference serial numers?
