Force 125hp wiring diagram
stuw pidasso
I have a 1988 force 125 hp serial # 2050 modal # 1251X8A. I'm going to replace My trigger with a remanufactured one but it does not come with a wiring diagram. Can someone Please help Me with a trigger diagram? I orderd a Manual but I don't know when it will get here.
Thanks
Gary
Jiggz
Re: Force 125hp wiring diagram
Here's one but not sure how good it'll come out. You might have to enlarge and print it out.
jerryjerry05
Look on the motor,if it's not been painted it should be there.
If you unhook any other wires cut the connectors off and replace.
That's the main failure on most triggers/stators.
Why you changing the stator??
stuw pidasso
I will try new connecters in the a.m.
I'm changing the Trigger because I may have gotten bad advice in the beganing, Not from this site.
Thanks for the info. I'm going to try new connections first. As far as boat motors go I can be a stuwpidasso
Thanks to Those who answerd
Gary
jerryjerry05
Sorry I meant to type trigger but it ended up stator:)
There are tests that can be done to make sure it's right??
