CaptainMcDonald
- Jul 17, 2012
- 1
Hi i'm a lost on trying to get started on fixing the issue with my boat. I have a 1989 Force outboard 85hp that has a power loss at wot. It starts every time with no issues and runs smooth until i try and give it full throttle. At wot i am sitting at only 3400 rpms for some reason and it will surge between 3400 and 4000 the whole time in the water at wot. But when i take it out of the water and hook up the water muffs it runs like a champ it will run up to 6000 rpms with ease. I have replaced the spark plugs and cleaned out the distributor wire caps that hook up to the plugs. I haven't done a compression test yet. Should that be my next step or is there other things to do also? Any help would be appreciated Thanks.
