mercurymang
Master Chief Petty Officer
- Jul 14, 2012
- 850
I have a new battery. When at full throttle, I am not charging the battery. I have read as much as possbile but am somewhat stuck. I believe the problem to be my voltage regulator but it could be my stator. My stator has two yellow wires, and green/white and a white/green. Can anyone tell me how it's wired. I'm getting around 6 ohm across the two yellow wires so I suspect the stator is ok but want to be sure.
I tested the voltage regulator and checked the resistance from yellow to read and read to yellow and get the same reading which would indicate to me a problem.
Just hoping someone could help me with some information.
