Roughneck1860
- Mar 30, 2008
- 41
I have a '92 150CFI. I believe its a '92. The serial number sticker can't be read but its on a '92 Trophy. My power trim motor runs but doesn't lift the motor. It appears to be low on fluid by looking through the hole on the right hand side of the trim motor housing. It has a knurled knob with an o-ring in the hole. Its also the trim motor with the built in side mounting bracket. What's the correct procedure for fill the resivour?
Thanks Tim
Thanks Tim
