Got a 74 Chrysler 55 hp, shop swapped motor from one baot to another and now generator doesn't charge. Found a black wire coming from under flywheel that is disconnected. It will reach what I would call a voltage regulator that has 2 terminals labled AC that connect to 2 red wires coming from under flywheel and 2 other terminals of which 1 wire is grounded to starter bolt. It had a volt meter on the olther boat, but they did not swap it. I am going to put it on the later boat. I am a truck mechanic and don't want to hook up the loose wire to the wrong terminal in fear of shorting out something. Any help would be greatly appreciated.
