Have a 90HP Force on my 22 ft pontoon. I was running it the other day with the cowl off and noticed exhaust coming up from under the motor. I did some research and decide that it must be the seal between the motor leg and adapter plate. I commenced to performing this time consuming task. Finished it up and it still smokes from underneat the motor. I have checked the "idle tube" as it is called that exits out the back of the motor leg cover. It has the accordion type shape. It has no tears. I am stumped. As you know, exhaust going into the intake is bad news. And it goes into the intake very willingly. Does anyone know what this could be? It idles poorly with the cover on, obviously.
