Im fairly new to maintenance and working on outboard motors. It seems the flywheel is not getting enough power to turn fast enough. I tested the starter by at first bridging the soleniod (not the soleniod as I got the same result) then direct current on the removed starter. It seems to be engaging and spinning freely. The flywheel moves with a bit of force. Any advice on what could be causing the issue, or what and where my next step in troubleshooting is? How would I know if the motor is siezeing, or i it's already too late? I could take it somewhere to find out but I would like to attempt a do it myself project. Hopefully know this motor inside and out. Probably best to learn a bit hands on on this motor,m before my next.
