bankbuster
- Jun 3, 2011
- 107
Hi all......Ive been working on getting this boat out all year. I had the shop check out the motor before I ran it......they tank tested it and said it was ready for the water. Well.......I took it out and it seemed to run great for the first 10-15 minutes. Then at about 80% throttle it felt like it was losing power so I threw it in nuetral. It idle fine. I slowly gave it forward throttle.....ran about 1/2 throttle for about 2-3 minutes. Then, just as a boat passsed and I approached choppy water (their waves) my engine lost power and almost died. I shut it down as I was confident that rough waters had loosened a connection somewhere. I pulled the hood and noticed my #3 (bottom cylinder) plug wire was melted just the boot). That cylinder seemed hotter than the others. Look at the pics.....is this just clogged carbs and or carbs out of sinc/adjustment?
