'91 90HP Force outboard - Colored Wiring Diagram Issue
If you look at this '91 90HP Force Outboard Wiring Diagram link: http://www.maxrules.com/graphics/force/wiring/90HP_1991D-1995.jpg
You see the item that has numbers 1 - 7 at the bottom right hand corner, the plug?
I do not have a plug on my motor, I have a connection block. The colors are correct, however I am looking for a diagram that tells me what goes where.
I do not have a plug to connect my engine to, as I stated I have a connection block instead...
I could label and hope nothing comes unlabeled but I just would like to have a proper solution.
Please point in the right direction... Thank you.
Jiggz
Re: '91 90HP Force outboard - Colored Wiring Diagram Issue
Here's one without the plug connector. You will need to double click it or save it to enlarge it.
Thank you Jiggz!! I am seeing if it will pring!! You have really helped me out a lot!!!
