Re: 355BA chrysler outboard. no spark to spark plugs.
Please send some close pics of what you are seeing under the flywheel. A list of what you have tried and results. I have enjoyed sharing from my 1970 35 HP Chrysler since 1984, that is how I learned a lot along with my Clymer Manuel. I also feel I had a slight advantage from automotive and small engine training and experiences mid 60s ? 1990.
Notice there is a post close to yours, "1973 45hp Chrysler no spark". You all need to team up on this problem, info and tests. Before the heat, I enjoyed running out to verify my suggestions and test but I?m guessing from memory and documented pics now. LOL. Repeated info is time consuming, if a search or manuel will show the info ?but not fast enough?. Most of all, you need a ?Local Friend With Hands On Experience? that will trade chores. I have welded and worked known repairs for firewood and yard chores. It Works with True Friends And Skills. Lecture 101, LOL!!
