I have a 1994 Force 120hp outboard. New to boating. Should my primer ball be hard when engine is running? Boat runs great when I start it up but dies after when I idle it down. It starts right back up but dies when I shift into gear. I changed plugs, but on new fuel filter. I checked the primer ball is soft when the engine is running? Should that be hard? The engine seems like it is not getting enough fuel.. THank you for any help....
