screeminreelz
- Jun 6, 2012
- 10
First off, I would like to say that without the knowledge on this forum I couldn't have fixed my motor as fast or as cheaply as I did - Thanks guys!
I have a 1992 Force 40 hp that was idling rough and not going into gear without stalling. I checked the compression and both cylinders were 125 pounds, which was a big relief. So then I took the carb off and cleaned it and re-installed it. The motor ran pretty good, but a little rough even with tuning so I ran some SeaFoam through it to clean the deposits. By the end of the treatment it ran a lot smoother.
Well, with that fixed I had another problem - the starter motor was getting weak. I tried two batteries, fully charged, and it still wouldn't turn. I took it apart and the brushes were worn at an angle. The commutator had a black varnish on it as well. So I scraped the commutator back down to copper, turned the brushes over so the factory flat side was up, cleaned the slides, and stretched the springs a little. Then I cleaned everything with carb cleaner and let it dry. I put it back together and shined up the connections with emery cloth. The starter was strong! Cost - $0 and about an hour of dinking around thanks to this forum.
The one issue I have still is that the recommended plugs are surface gap, but the motor will not run on them. I bought new ones and it will run, but only sometimes and with a lot of cranking. The standard plugs work great. Anybody have an idea why, or how I could fix it so it would run on those plugs? I heard regular plugs could be too hot for the motor, etc., so I would like to get it going with the sg's if possible.
Thanks again to all the people with knowledge willing to share on this forum. Remember, if you fix your boat - post the results so everyone can benefit. It is easy to fix it and then go boating and not follow up, but it is important so that people with the same problem will know what worked.
Brian
Brian
