SwampThing
- Nov 6, 2006
- 117
Would anyone happen to know which switch I would need to order to replace the OEM switch? Looking through the catalog here gets confusing as heck. Couldn't find a part number to cross reference it with, old switch only says "Indak" on the back side with no part numbers.
In dash mount, 3 position, off, run, start, (spring return from start, 6 screw type terminals, and the current one is the longer shaft style.
Any help would be appreciated. And yes it does need replacing, this one is wiped out and doesn't return from the start position. Concerned that I'm going to end up damaging the starter eventually.
