Basstrackerpro17
- Feb 14, 2012
- 8
I dropped the lower unit on my 1990 Force model 507F90C 50HP motor to change the water pump impeller. I found a piece of rubber, like some kind of rubber seal or boot torn in half just laying in there that I have no idea where it came from. The only two places I think it might could come from is at the top of the tube that slides down in the water pump or maybe at the top of the drive shaft that goes back into the top of the motor when you slide it back together. Does anybody have any idea where this rubber seal might go? Thanks.
