1987 Bayliner Trophy with 125 Force. I took the boat out a couple weeks ago and no problems at all with the steering. I arrive at the boat today, planning on taking it out, and the steering is frozen. I tried a couple different things in order to better understand the problem. I disconnected the engine from the steering rod by removing the bolt at the L shaped bar. The engine moves freely with no problems, but the rod will not move via the steering wheel. I then disconnected the large nut where the cable connects. I was able to move the rod by hand, although it was rather hard to do so. Still, the steering wheel does will not turn all the way neither port nor starboard. When turning the wheel, it gets to a point where there is a clicking noise coming from what appears to be a gear housing directly beneath the wheel. Can someone help me understand what needs to be done? Thanks
