1988 Force 125 runs and idles fine. Last year this issue was intermittent and got worse as fall set in. Took it out Easter moning when I pull out of the marina and throttle up the motor RPMs come up a little but not much even if i pump the bulb. Fuel pump diaphram is good. Compression 120, 120, 122, 125. I suspect carb issues. Any ideas.... I'd like to try and pull both carbs and clean them but scared of syncing them back up.....
