Re: 1983 85hp Force not charging battery
Even if you do get stuck with a dead battery, with the key in the run position, that engine can be pull started and will run. Just carry a good stout rope about 4 feet long with a handle on one end and a knot on the other.
For some reason I can't post my photos, but if you search for my post on pull starting you will see me doing it with a 125.
Practice once or twice before you need to do it, then take your time finding parts.
As stated above, a stator is not real expensive and only requires removing the flywheel to replace--not a difficult job and you CAN do it yourself. Why discard a perfectly good engine for such a small problem?
