I am having problems with keeping the my 45 hp chrysler outboard running. I think it is a fuel issue. The motor will start up and idle good for a little while but when I get to going the motor starts to cut out and dies. To get it started again I have to pump the primer bulb on the gas line. I have taken apart the carb and cleaned it good. It has a new gas line with primer bulb from the tank to the motor. When you try to prime the motor with the bulb, the bulb does not seem like it is releasing back as quick as it should (it stays collapsed for a little while). Anybody have any ideas for me? Thanks
