Ok, you guys will have to forgive me.....and talking down to me is ok, as I may need it. I just bought a boat a few weeks ago....it's equipped with a 1970 Chrysler 55 HP, model number is 557HA. I can get this thing to start with some starter fluid, but it doesn't want to stay running.
This is my first boat, so I'm sort of learning as I go. I'm actually more of a car guy, so I'm having to transfer that knowledge to outboard motors.
As far as what I've done: have drained and refilled the gas tank, 50:1, which apparently is the ratio. Have replaced the ignition switch(magneto circuit, and I don't feel this caused a problem). I have removed, cleaned, and re-installed the carb, and the fuel pump.
Based on other threads I've read, the next step would be the points....
I pulled up a pic of the points on Google, and I'm actually not able to locate them on this motor....last time I saw points were on a 70 Ford truck under a distributor cap. Obviously, outboards are a bit different. If someone can point me in the right direction, and possibly offer some other possibilities, it'd sure be helpful.....otherwise I am in the market for a new outboard. Thanks!
