Ok I took the boat back out today and was very happy for a couple trips around the lake. After starting and stopping a three times I took off again, the boat planed out I slowed to a crawl for an on coming fisherman and took off again. She once again planed out again but after a few moments the motor began to pulsate and lose power. I stopped, removed the spark plugs and the third cylinder looked dry compared to the other two. I took off again a couple times with the same results. It definitely seems to be a carb/fuel issue.
What could be causing this problem? It definitely seems like a fuel delivery problem to me?
Seems that this float/needle is sticking Closed to me? How could this be happening?
I have replaced the fuel pump diaphram. Is there anything else I could do with the Fuel pump? Jets to clean/replace inside the fuel pump?
What I have:
1988 Force 85 hp On a Bayliner Capri 1700 (856X8A)
What I have done:
-Checked compression 125 on all cylinders when cold
-checked all ground and ignition wires for solid connections
-replaced Trigger
-replaced all fuel lines and bulb
-checked for spark - have good spark on all cylinders
-replaced fuel pump diaphram
-removed and cleaned all carbs
-checked and adjusted timing.
What I have:
What I have done:
-replaced Trigger
