I recently got the boat out to crank it after the winter, I did use stabil, and when i went to crank it it turns over very slowly and no crank. I did however get it to fire up one time and it fired up very quickly but that was the only time. I was thinking it could probably be some corrosion on the battery cables, which there was some corrosion, and i clean it somewhat off but didnt help. I did not check the cable connection to the actual motor but just to the battery. I was just wondering what else it could be or if in fact it is just the cables. thanks
