I have a 1998 Force 50 hp. and just had the lower gears serviced. *I took it to a mechanic who said the gears were fine, but the "single piece" lower cowling was loose (possibly bad gromits) causing a problem with the shifting mechanism. He did show me the loose cowling and told me the condition could cause unintended shifting problems.
I took the boat out and the engine ran fine in forward. The reverse gear would not engaged and grinded. I only had to do it once to know something was terribly wrong. *The lower cowling did vibrate a little much. *My mechanic says to fix the reverse shifting problem requires the removal of the power head and insertion of the new stabilizing grommets ($550.00+). Does this sound right? *I need a second opinion. *Thanks to all in advance.
