greasemonkeyjmj
- Jul 7, 2008
- 264
hello I came into possesion of a 1977 chrysler 15 hp the engine was running until the fuel bowl corroded and developed a leak in it. well it set for approx a year without running. i took the bowl off and patched it with some quick steel. now the engine will not run. it gets fuel into the carb bowl, but it will not get fuel into the engine. i can squirt premix into the carb throat and it will start and run until it burns it out. I tore the carb apart, but didnt see anything in the jet or the tube running into the carb throat. i went ahead and soaked the carb for 4 days anyway. and blew every thing out with compressed air. after putting it back on, there was no change in the symptoms. I cant reach the throat of the carb to put my hand over the front of it to see if it has a suction to it. the previous owner pulled the carb off but i am not sure if they tore into the carb or not. any help or ideas will be appreciated as usual.
