I was wondering what lower gear unit oil these old Chryslers prefer? I've seen Quiksilver around, Supertech from wally world which I probably wouldn't buy, Lubrimatic from Gander Mountain? Just wondering what other people have successfully used. I've had the boat for about two years and haven't changed it once, just stored it for winter, so I'll be doing it this spring.
Also, as far as spark plugs go...I know to use the L82C's on this engine, but was wondering what the correct gap I should set these plugs at that would help the old chrysler run smoother...I'm pretty sure they come pre gapped at .02 but i read somewhere that you should have the plugs gapped to .03 or .04?? Another issue that I've read somewhere is not gapping these plugs or you can melt a hole in the middle of the piston? Someone please clarify....
