What is the best way to check if a spark plug lead is producing current? I only have spark at the top cylinder but it is strong and even enough to run the motor. I have a mini tacho that wraps around the plug leads and reads the RPM. This reads on both leads, so unless it is reading off the top lead the bottom lead may have current and the boot may be faulty?? Both plugs are ok as I have swapped them and the top lead sparks with both plugs.
Is there a way to replace the boot without replacing the lead, as the coils are under the flywheel.
Thanks.
Thanks.
