My 1987 125 HP Force outboard has very stiff steering, even with the linkage disconnected. Word on the forum was that the bracket that the king pin goes through often corrodes, expands, and "pinches" the king pin.
I bought a used steering bracket (the component that the vertical king pin goes through) off eBay, and it turns freely. (Like this one, only not so pretty, but it swivels freely: http://www.ebay.com/itm/Force-Outbo...Gear&vxp=mtr&hash=item4aa92c5e4b#ht_814wt_698)
So, I am getting ready to try disconnect the bracket and pull the motor off this weekend.
It looks like it's attached to the motor and motor leg with just two big (rusty!)bolts going up into the front motor mount from underneath and six small (stainless steel) ones going into the sides of the motor leg.
Any advice for pulling these? Current plan is to heat the bolts and try to back them out a little, then suspend the motor by the flywheel with a hoist, put some tension on it, and remove the bolts.
I'm concerned that they bolts may break, or that the mounting holes that the bolts go into may crack.
