bigchunkytaco
- Feb 6, 2011
- 54
gday i have recently mounted a second hand 115hp chrysler,
ive got it cranking and have wired the tacho, it has an "s" to the tacho terninal on the engine, an "I" to the ignition and a ground.
now trying to wire up the hour meter and trim gauge, the trim has the same terminals on the back, (S,I,Grd) but the sender on the transom bracket has 2 bare wires... which is tooi many..
the needle is also a quarter of the way up so am wondering if its actually buggered anyway? the hour meter has 2 terminals on the back not sure where to wire them to..
i have the clymer manual but its no help for accessories... just wondering if anyone has a wiring diagram or is knowledgable with these components? im sure its not that hard but id prefer to wire it right the first time
cheers!
cheers!
