maverick974
- Jun 26, 2009
- 122
My engine has always run perfectly in the 4 years I've owned it with the exception of when the fuel pump diaphram failed a few years ago. Barring that, it has always brought me home.
I live in Arizona so I can fish all year long so a few days ago, I was taking the boat off the trailer and it idled badly. I pulled up to the dock to check things out and magically it started running perfectly, almost like someone flipped a switch. I figured just a little something got stuck in one of the carbs or something. I didn't give it another thought. I cruised across the lake and went fishing. When I cranked up the engine to leave that spot and try another, it idled badly again until it warmed up a little bit. That's the way it was all day. It idled poorly until it warmed up a little and then ran fine until it cooled off.
I'm a little concerned because that sounds electrical to me and I know the power packs are not cheap.
The compressions is within 5 pounds of 150 on all 3 cylinders and I just did a link and sink about a month ago.
What would be the first thing I should look for?
Any suggestions?????
