mikechrisclark
- Nov 21, 2011
- 1
I have a 1988 force 125 hp. I am having problems with the electrical. when I try to hook up the battery I get sparks from it. I went thru the electrical wires and found that if I remove the ground from the rectifier it did not spark when I tried to hook up the battery. It did however get so hot on the positive post while trying to turn it over that it melted the positive cable. The conections on the battery where clean and tight. When the ground is hooked up on the rectifier and I ignore the sparks on the cables the curcuit breaker pops. I realize I have a short somewhere but before I start buying parts i wanted to know if anyone else has seen this problem. Is it the starter, rectifier, starter selonoid, or something else. Engine will start but something is wrong and I want to fix it right. please let me know if you have any ideas. Thanks
