bailey1158
- Nov 15, 2011
- 6
I have tried to use four 5/16" threaded rods and a puller to remove the bearing carrier and had no luck, we probably had about 6-8 tons of pressure on it including heat guns and it did not budge one bit. am i using the correct holes to be pulling on or should I be using the 1/4-20 holes? This is my first boat and I want to make sure I replace all the seals correctly as I learn. Is it at all possible that the cast aluminum has ceased together over the years? The lower unit runs fine, Im just trying to do my preventitive maintenance to increase the life of the unit, any thoughts?
