seattle scott
- Nov 1, 2011
- 113
Wasn't getting any fuel past the pumps so I am in the process of rebuilding them. When I removed the lower fuel pump (pump cover part FA439746) it had a brass tube extending out the back into the crank case area. The top pump didn't have this tube and the tube is not shown on the fuel pump parts diagram. Anyway, the tube must have fallen out of the pump cover between the driveway and the work bench and is lost.
So is the engine going to run fine ( at all ) without the brass tube?
