LostCoastDreamin
- Sep 29, 2011
- 22
I just took apart the lower unit in my 1977 65 hp Chrysler, and found a mess of metal in the gear housing. Forward gear has large chunks missing from, or cracks in, all the teeth, so it needs repair or replaced. Is it even possible to repair teeth on a spiral bevel gear such as this? Can a machine shop handle it? I have a nice arc welder (up to 180 amps) but my metal machining tools are limited to bench and hand grinders, drill press and rotary tools. No metal lathe here.
I have only had this on the water three times, and it was hard to engage forward from the start. Now I know why. The third time out, I felt something "let go" while under way, followed by a COMPLETE loss of all power. Had to get the tow of shame. This would be the last bit of grip between the drive shaft and the pinion gear shearing off/pinion nut loosening. I am more and more sure the drive shaft-to-pinion teeth were already stripped, and the last owner just tightened the nut back on and sold it to me. My fault for not testing out the lower unit before buying it. Surprisingly, the pinion gear itself looks pretty good inside and out. So does reverse.
After taking apart the unit, I discovered the reason for the total loss of power. The nut on the pinion gear backed its way out enough to stop holding the drive shaft, but the main issue is that the drive shaft teeth are stripped. Turns out they are so completely stripped that no amount of pinion nut tightening would fix it. I'm pretty sure I can weld enough metal to the drive shaft to grind the teeth back into it, and have a solid grip there again.
The clutch dogs are slightly rounded, but I am sure I can repair that. Fairly simple welding and grinding on square dogs. That means two out of three problems solved if I'm right about being able to fix them.
Is it even possible to repair teeth on a spiral bevel gear such as this? Can a machine shop handle it? Does anyone else have a forward gear that would work for me? I've heard that several years of 55, 60, and 65 Chryslers have the same lower unit, something like '73-'78 for years. Please PM me if you might have a replacement for me.
