Hi I have tried off and on through the summer to get this boat running. My dad got tired of seeing me struggle so he bought a boat that we have enjoyed. Well i need to get this fixed and get it sold. So i took it to a boat mechanic that said it has a bad starter and bad plugs.
Ok the starter was new in March the previous owner put it on and i have the receipt. Wires are heavy guage and original. Solinoid will light up my test light when the key is on. He checked the compression (150 on both), spark and maybe sometbhing else. But it cranks slow. I thought from reading on this forum that it was a fuel problem creating compression and thus not starting. Primer buld is always firm. There was a water leak from exhaust plate gasket that i fixed. I would guess that during our last successful outing the motor ingested water from the cowl filling with thsi water. But that water is long gone as we have had it on the water since then. Just didn't start consistently after that. The way it cranks you would think charging or battery. So i now have another new battery (thinking maybe first new one was bad) and i replaced the voltage regulator. Oh i replaced the plugs shortly after i bought it becasue they were original. Recent mechanic said they have fouled due to no starts from the starter.
I really want to be sure before i go removing the starter and tring to exchange it where it was purchased. Maybe they will maybe they wont. $159 is what the receipt is for. Any tips would sure be great. thank you in advance
