Overheated my powerhead and I'm in the process of replacement.
There's a vertical divider plate on the motor leg that meets up with the powerhead seperating the exhaust and the water pickup tube. Is there suppose to be a seal in there for that? Is it common to have exhaust blow by in the section of the motor leg were the water tube/water pump is? It seems like this may have been part of the overheat problem, theres a lot of sand and oil in that section.
Thanks for your help
Bryan
Bryan
