BrandonKnight
- Sep 12, 2011
- 10
i have to admit i'm new to boating and inexperienced when it comes to engine repairs. i bought a boat recently and was under the impression that all it needed was a new impeller and it would work fine, there were a couple of other problems that i fixed and im actually enjoying the project but this recent one has me stumped. i took the boat out on the water and started it up, the boat runs great and starts every time the boat will reverse properly and switches gears properly but when i go to put it in forward it will only go at a very low speed if at all. if i give it more gas it will either slip the gear or sputter and die. it may be unrelated but i have also noticed it runs slightly better with the top cover off, some things i read say that could be an exhaust leak but i figure it might be pertinent. my strategy right now is to check the shift rod and cables to make sure it is shifting properly into forward but i wanted to see if somone else had any ideas.
