Re: steering cable frozen
Where do you apply the heat to these.
My 1978 85 hp merc cable does not move.
I have a collar nut on the starboard side of the steering tube that I can remove and get the cable to move away from the steering cable tube.
I do not see a nut on the port side of the steerign tub. here is a little bar protrudes with a hole in it that has a threaded linkage bar go through it that connects to the motor. It appears this little protruding bar is supposed to move in and out to controll the steering of the outboard. Do I hit this bar with the heat?
Also when I put a grease gun up to the nipple on the steering tube it did not want to go in. I assume it did, but after ten pumps I did not see it coming out of any seals. I just saw small incriments coming out of the grease gun tip area. (not the entire pump, I'd say only 10% of the pump.)
