OldFaithful
- Sep 7, 2011
- 2
Hi Everyone,
I apologize in advance for my lack of knowledge about boats/engines
I recently obtained a fiberglass boat with 35 HP Chrysler motor.
I am having challenges getting the motor to stay alive.
When I turn the key, the starter kicks in, the motor starts and the key returns to position, the engine dies.
Accidentally, I found that if I turn the key and the engine starts, if I hold the key "turned" and put the boat in forward, drive, it stays alive, but I have to hold the key turned like in start position. If I let the key go back into normal position, the engine dies.
I don't know if this is doing more harm than good, but maybe this can help pinpoint the issue with the engine.
I wanted to attempt to solve the problem on my own, with your help and guidance of course However, if this issue is a complex one I will just take the engine to a marina for repair although I do not want to invest further money into this engine.
If anyone has any recommendations on what I can do, fix, replace to make this engine run as it should I would greatly appreciate it.
Thanks for your time
-- The model number on the engine is: 3542, not sure if that helps or not, thanks
