yoyopurple
- May 27, 2011
- 4
Hi so im kinda new to this site, i have a 85 force its a 87. i bought tons of stuff to try to improve performance, but its still giving me some headaches.
So i change 2 coils, IMPELLER,FUEL DIAPHRAGM, PORT COVER GASKET, INTAKE MANIFOLD GASKET, SPARK PLUGS. did a compression test 1# 115 2#115 3#114
when start it fires up, but when warm sometimes i have to choke it to start it when its warm. im at WOT turning 4500 but running to lean.
i go to fix the idle air screws but the first carb, at 1 1/4 screws revs hi like it should but misses and coughs like no other. THE BIG PICTURE is that when my carbs are adjusted like how the settings are suppose to be, it misses at a idle and kills the boat. But if i can get it to run at all 1 1/4 turns it turns 5000rpm but wont idle because it sneezes and coughs like crazy
