i fixed the over heating problem, than it stopped charging; so i replaced the voltage regulator. now the charging system works fine again but at 3/4 to full throttle it surges up and down. from idle to 3/4 throttle its fine. all fuel line, filters, pump diaphram were replaced 3 months ago. i think i will disconnect the hot wire on the regulator and try that the next time on the lake just to see what happens, what do you think?
