Hopfully this will be a quick fix question.
1) I replaced the CDI Ing. pack in this engine. While trouble shooting it, the coil packs may have gotten switched around. In reading the manual, it shows that one is postive ground, and the other is neg ground. Does it matter if there switched? Does one have a longer sparkplug cable length?
2) Which cyl is #1. Is it the bottom one? Manual does not tell me which one is the correct one.
Trying to get back into the water on Saturday. Don't want to screw this up.
Thanks,
Jim
Thanks,
Jim
