Hi,
I'm new to the forum (and to boating). Bought a 19' Trophy '87 CC with a 1995 120Hp Force. Run the boat on the water last week and it took me a lot of effort to get it started when the motor is cold. Once it has run, it starts within a second. I used the primer (choke). I lifted the boat due to Irene and while having it around the house over the weekend I changed the sparks plugs. However, same issue. Ordered compression tester and spark tester at Amazon to perform tests later this week.
To me it looks like it doesn't get the right mixture of gas for a cold start (or not enough gas at all). Primer works, I checked. Anybody have some suggestions where to look?
Another thing that bothers me, while on the water we were able to get her to 32-35 Mph WOT on the build in speed meter. But the engine was still at 3,000 rpm (instead of the expected 4,700-5,200). I've a 17" pitch prop. Still not sure if it is the tacho, need to run her at the water with an external tacho connected to be sure. My thought is that it almost impossible to reach 32 Mph at 3,000 rpm with a 17" prop. Suggestions and comments how to investigate are very welcome.
Ton
Ton
