help... after redoing the interior and reinstalling the shifter/throttle control in what i was certain was the same position as removed - apparently not - i can not find 'neutral' while giving it any gas to start. i can get it in neutral easy enough and the motor turns over but as soon as i pull the button on the shifter up to throttle it up in neutral, the shifter moves the linkage for the trans and the little 'in gear' sensor switch pops and kills the starter. ive also noticed the throttle linkage then becomes blocked by the little 'foot' preventing revving while in neutral. something is obviously out of sync. see attached pix might help. help please.
