My 40 HP Force 2 stroke does not have water flow. It was spitting some last fall when I bought it, so I did an impeller change thinking that would solve it. No luck this summer when I tried it and it heated up pretty quick - no water flow at all this time. Let it cool down and restarted it - don't think I hurt it much. Pulled the lower leg and the impeller looks fine, still like new. Blew some air up into the pickup tube to the head and could hear air blowing out freely inside but nothing coming through the outlet. Is there a connection to the cooling passages that may have come off or is wasted, either at the pump discharge or at the top where it goes into the block? Maybe a blockage or a thermostat issue? Please help.
capeape 56
capeape 56
