Re: 1988 15 hp gamefisher/ force- wont run
Ok if it still will not run with the cover off then that eliminates an exauast leak and timing issue at that point. Do a compression test and post what you get, and also have you tried to turn up the idle a bit and then see if it runs in the water. I had to turn mine up and it made a huge difference
in the idle.?
