Re: 1985 ,90 hp Force trim and tilt diagram picture
OK, as they say, "Good description is worth thousand pictures". Thank you RRitt, your description was very helpful, and I was able to connect everything properly.
But, since I was looking for pictures and didn't find them, I have decided to photograph the whole process and post the photos for the future use on the forum.
Here we go:
This is what I had at the beginning
I have bought a used tilt and trim setup and it came with to relays and a circuit breaker. The first challenge was how to bring this "bunch" under the cowl. Following RRitt's instructions I found holes on the bottom of the engine pan underneath the carbs.
Short from splicing the wires I didn't see any other way to bring the relays and circuit breaker in:
It worked fine.
Next, I found these two threaded holes to the front left side , just left of the carbs (looking from the back):
Got some machine screws of the same thread and fit two relays perfectly:
Next I fount these two holes (same thread) next to starter solenoid:
and placed the circuit breaker there:
see the next post for picture
Than I connected red wire to the starter solenoid front bolt and the two black wires to the starter ground bolt.
My motor came already wired for the trim motor:
(see the next post for picture)
and that was the easy part.
Than I looked under the instrument panel and both wires were connected to fuses. Took them both of fuses, connected them to top and bottom terminal of a simple stupid switch: (see the next post for picture)
I brought the plus from the fuse to the middle terminal and : VOILA! UP AND DOWN, UP AND DOWN...
Hope it helps a lot of people!!
