Hello all. I have a 1307HA Chrysler. I posted some pics of it some time ago under the title of 1972 Chrysler 130 model 1307HA Are the worth putting money into. The motor turns over and I have power to the coil but no spark out of the coil. I am in need a diagram of what the wiring should look like after a coil conversion. While tinkering today I found a red and white wire that dead end on the coil side of the motor. they are both connected to the wire block. The white should be for the tack and the red should be for the battery according to the tag on the motor. I tested both wires and found the red to be live when the key is on. I need to know where this wire belongs. My guess is this is the cause of the lack of spark.
Thanks
Thanks
