This builds on a previous post with this motor that misses after about an hour. I've sorted out eh electrical, and now have a couple fuel questions. I rebuilt the card (mostly gaskets and needle/seat). I adjusted the float per instructions, but when starting it up I had to apply some throttle to get it to idle. I adjusted the idle screw to fix, but would this be caused by a mis-adjusted float? Secondly, the glass fuel bowl leaks when you pressurize the system with the primer bulb. It has a new gasket, is this normal? I just replaced the bulb because it gets soft after start up and fuel barely dribbles into the fuel filter. The engine no longer misses when run in a can (2 and 1/2 hours), hopefully a real world test will prove to be the same.
