Does anyone know where I can get a drive shaft and prop seal for a old 6hp Chrysler model number 6701? If not does anyone know the original part number for these parts?
The seals have been removed and replaced with parts that are not right, so I don't even have the original seals. Also is there a drive shaft seal in the top of the water pump housing on this motor? there is not one there and does not appear that there ever was was. FYI this water pump housing has 3 screws that mount it. I know there were different versions with 4.
Thanks in advance for any help.
