chrome dome
- Sep 24, 2010
- 303
G'day again,
when turning over my son's 120 hp 1976 motor the other day the bendix gear did not disengage but stayed up on the flywheel, l had the cowl off so saw it straight away ( motor is on a stand ) and turned it off
l assumed the shaft and gear just needed a bit of a clean up and a shot or two of WD40 but that didn't work, l gave it a couple of light taps with a rubber mallet and it dropped down again ok but is still staying up today even with grease
while turning the shaft by hand l realised that there was a fair bit of sideways play in the shaft, which none of the other brand outboards have, l had not noticed it before but then l hadn't had to touch the starter on this before either
so, finally, that is the question, how much play is normal/acceptable/ or is that normal for a chrysler
or " renovate or detonate?"
rebuild or replace
cheers
rebuild or replace
cheers
